NAPA, Raybestos, or ACDELCO wheel cylinders?
Old Jan 14, 2015 | 11:06 AM
yeahbuddy's Avatar
Time to replace rear wheel cylinders on 68 Cutlass Surpeme w/ drums all around. The wheel cylinders on there now are cheap Autozone parts that are leaking after 3 years of use. Going to buy some higher quality ones and I have three options. Between NAPA, Raybestos and ACDELCO which one would be the greatest quality? I can get the NAPA at wholesale for $22 each (Normally $49 each)
Old Jan 14, 2015 | 11:08 AM
pavemobile's Avatar
pavemobile
I have used Raybestos Professional line with good results.
Old Jan 14, 2015 | 12:56 PM
rocketraider's Avatar
Oldsdruid
Second on the Raybestos or Wagner if you can find those. NAPA should also be good, but I can about guarantee ACD are now made offshore in same factory that made the AZ pieces.
Old Jan 14, 2015 | 04:51 PM
Lady72nRob71's Avatar
I have had very good luck with Wagners and Raybestos.
The factory ones in the Pinto were Wagner and lasted 14 years before a leak occured. I replaced them with Wagners and those lasted 23 years. I just replaced them with more Wagners for hopefully another 20 years.
My 86 Olds factory ones leaked after 7 years. I replaced them with Raybestos 22 years ago. I checked them last month and no leaks yet.
My 72 has leaky cyl's but I do not know the make. I have Wagners awaiting for nicer weather.
Go figure...
Old Jan 14, 2015 | 05:49 PM
I've had good luck with Raybestos also. I buy those parts local.
Old Jan 14, 2015 | 05:52 PM
Yes.
Old Jan 15, 2015 | 06:22 AM
oddball's Avatar
I highly doubt there's any noticeable difference between those. Good chance they all come from the same factory.
Do disassemble and inspect whatever you get. I got a cylinder with a seal folded over. Gotten several master cylinders with scratched bores.
Old Apr 5, 2015 | 01:52 PM
bob p's Avatar
Rocketeer
NAPA's brake parts are made by Brake Parts Inc. Raybestos is one of BPI's trademarked brands. I don't think you'd find much quality difference between a NAPA or a Raybestos wheel cylinder.
That said, you can find some subtle differences between the BPI Raybestos wheel cylinders and the NAPA wheel cylinders -- pay attention to the bleeders. Sizing of the bleed screws may be different.
When increasing the diameter of the rears on my Suburban I made the choice between NAPA and RB based upon the size of the bleeder that matched my OEM-spec bleeding wrench. Had I gone with the other I would have had to buy another bleeding wrench in the new size.
The catalogs are very helpful. Watch the details if this matters to you.
bob p
Brakes/Hydraulic Systems
18
May 6, 2015 03:17 PM
RockAuto
Jan 23, 2013 12:14 PM
84oldsDelta88
Jun 24, 2009 03:40 PM
