Master nut size ?
Old Feb 28, 2025 | 03:17 PM
Bigmikey65's Avatar
Master nut size ?
The brake line from the master to the metering valve on my ‘70 W-30 4 speed (front manual disks) was dripping brake fluid from the master side of the line. I tried tightening the nut at the master to no avail so I ordered a new one from Inline. On the line that’s in the car now the nut at the metering valve is 7/16” and the nut at the master is 1/2”. The line that Inline just sent is 9/16” at the master and 7/16” at the metering valve. So it’s 1/2” mine vs. 9/16” theres. Before I take the old line out (the new one will probably not fit anyway) does anyone know what the correct size of these nuts is supposed to be ?
Old Feb 28, 2025 | 06:19 PM
70Post's Avatar
Just checked two KNOWN '70 ORIGINALS. Both lines have a 7/16" and 9/16" wrench/nut sizes across the wrench flats.
Old Feb 28, 2025 | 06:23 PM
70Post's Avatar
Checked two more known '70 originals.....same sizes on them as well.
Old Feb 28, 2025 | 08:01 PM
Bigmikey65's Avatar
Thank you Patton.
Old Mar 1, 2025 | 05:20 AM
VC455's Avatar
Barely Registered
Mike, if you have any problem with the fit of the new brake line, a quick, but permanent, fix is to install a Brake Hydraulic Copper Gasket to seal your existing line.
Dorman makes them and you can get them at a local auto parts store such as NAPA.
Gary
Old Mar 3, 2025 | 08:40 AM
Bigmikey65's Avatar
Thanks Gary.
ourkid2000
Brakes/Hydraulic Systems
33
Apr 11, 2025 08:40 AM
Bigmikey65
Dec 5, 2024 09:46 AM
Tancuda
23
May 25, 2024 06:32 AM
sysmg
May 29, 2019 01:17 PM
harascho
Feb 10, 2014 02:11 AM
