Master Cylinder Brake Hose
Old Sep 26, 2022 | 01:37 PM
tricordati's Avatar
Power Brake Master Cylinder Hose
I need to replace the power brake master cylinder hose on my 1956 88 and would appreciate any words of wisdom (it’s a Moraine unit). Thanks
Old Sep 27, 2022 | 06:37 PM
tricordati's Avatar
I need to replace the brake hose on the master cylinder on my 1956 88 and would appreciate any advice. Thanks
Old Sep 29, 2022 | 04:23 AM
Have you checked Kanter and Fusick? If they don't carry the part you need you may be able to have a hose built at a hydraulic specialty supplier.
https://www.kanter.com/
https://www.fusickautomotiveproducts.com/
I merged your threads. No need to have it in 2 places. Good luck.
Old Sep 29, 2022 | 08:49 AM
tricordati's Avatar
Thanks but looking for insight on how to replace it.
Thanks I did order one from Fusik but I was looking for any insight as to how to replace it.
Old Sep 29, 2022 | 02:30 PM
sysmg's Avatar
Not sure how much experience you have with hydraulic systems. But if you have none, you are better off having a mechanic do the job. If you make a mistake your brakes could fail and you could get in an accident.
'46-98
Brakes/Hydraulic Systems
Nov 22, 2018 11:00 AM
gonepaddling
Mar 22, 2016 01:09 PM
chip-powell
Aug 3, 2015 01:35 PM
bajaway
Mar 22, 2010 09:36 PM
