Master cyl-prop valve rebuild
Old Oct 5, 2025 | 05:38 PM
Bigdibbs88's Avatar
Hi Guys- i was able to find some guys to rebuild the original water pump and starter on my 67 442 and they turned out great. Wondering if there is anyone recommended who is able to recondition the original master cylinder and proportioning valve? Thanks for any help
Old Oct 6, 2025 | 05:30 AM
oddball's Avatar
Check RockAuto for master cylinder rebuild kits. A little bit of rust in the bore can be cleaned up with one of those brake cylinder bore hones from the parts store. Rebuilding a master cylinder is extremely easy. Remove the c-clip, knock out the pistons, push in new pistons, install c-clip.
There's a decent chance that the internals from a replacement prop valve will slip right into an original prop valve. They just use a brass block because it's quicker/cheaper to machine than to make and machine a casting. Never taken one apart but it can't be too bad.
Old Oct 6, 2025 | 06:15 AM
Bigdibbs88's Avatar
It’s a very real possibility that I’m stupid, but I can’t seem to find a proportioning valve rebuild kit anywhere. Any leads? Looks like there might be some master cylinder rebuild kits though
Old Oct 6, 2025 | 06:17 AM
A 1967 442 didn't come from the factory with a "prop valve", not even with disc brakes. Post a photo of the thing you are talking about.
Old Oct 6, 2025 | 06:33 AM
Bigdibbs88's Avatar
I suppose distribution block would be a more correct term
Old Oct 6, 2025 | 08:48 AM
Well since it is neither "proportioning" nor "valve"...
Old Oct 6, 2025 | 08:57 AM
ROCKET VAPOR's Avatar
Lance
Rebuild kits
https://www.musclecarresearch.com/gm-parts
Old Oct 14, 2025 | 02:58 PM
Tancuda's Avatar
Originally Posted by ROCKET VAPOR
Same situation here for the valve, I have a 71 cutlass, front disk brake, do I need the 2 kits listed for the Iron valve ? gm-pd-valve-kit-1 and gm-pd-valve-kit-2
Tee Ro
Brakes/Hydraulic Systems
Dec 28, 2024 05:56 PM
Bigmikey65
Oct 27, 2023 04:44 PM
Kevin W
Jul 11, 2022 11:54 PM
Vader
Nov 1, 2021 11:29 AM
Zr1bandit
Mar 18, 2020 07:52 PM
