Low cost front disc brake conversion
Old Feb 5, 2009 | 06:40 PM
OLD SKL 69's Avatar
GM Enthusiast
I found this bracket kit on ebay to convert over from front drum brakes to disc. They say you bolt them in, go to your local parts store and buy 1990 Celebrity calipers, 88 Monte rotors, and brake hoses. You don't even need to change the proportioning valve, m/c or vacuum booster. Can probably buy all of the parts necessary for under $300.
SCAREBIRD DISC BRAKE BRACKETS Item number: 370152732996
Some companies offer expensive conversion kits, using custom rotors, calipers and pads available only through them. We offer affordable conversion brackets that require no special pieces; using low cost items available through local parts houses. Total cost usually runs approximately $300-450.
My questions are:
Has anyone used these kits and is this setup going to be strong enough to yield an improvement in stopping power?
Old Feb 5, 2009 | 07:01 PM
Or, you can just use factory-style parts for the same amount of money:
https://classicoldsmobile.com/forums...sk-brakes.html
Old Feb 5, 2009 | 07:08 PM
lshlsh2's Avatar
71 cutlass convertible
It looks like it is only for one brake you would need two kits. I have no idea how it would work but I think I would do a regular conversion. Brakes are not somthing to jury-rig.IMO
Larry
Old Feb 5, 2009 | 07:40 PM
OLD SKL 69's Avatar
GM Enthusiast
The kit you quoted looks great but it costs 500-600, and also requires changing the m/c and proportioning valve as well. The cost is almost 2x what this kit costs.
Larry
I believe it is a bracket kit for both sides.
But I agree with both of you that I would prefer to do a regular conversion. I was just curious to see if someone has seen, heard, or used this kit.
Old Feb 6, 2009 | 10:04 AM
Any drum to disk conversion requires changing the M/C and adding a proportioning valve. Note that your existing drum brake spindles can be modified to fit the stock caliper brackets with a very minor machining operation.
Old Feb 27, 2009 | 05:39 AM
rockethound's Avatar
i went to the local junk yard and robed the front disc brakes from a 71 cutlass for about 200 and just had to sand blast and paint. pretty easy
Old Feb 27, 2009 | 08:22 AM
That is always the easiest and best route, but unfortunately A-body cars are becoming scarce in wrecking yards. The ones that are there are usually quickly picked clean by either restorers or folks with ebay businesses.
Old Mar 1, 2009 | 04:59 PM
ya i can see that to be true but were i'm located in mi there are still a-body cars around
in yards. but your write they are starting to get picked over but i have three yards that don't crush that i have found while driving up north one write here in town tho.
joe_padavano
Tech Editor's Desk
150
Dec 24, 2025 06:18 AM
Mocephus
Oct 1, 2021 09:45 AM
cutlassjoe
Mar 20, 2015 10:14 PM
carlosman
Mar 6, 2014 09:29 AM
Maverick
Brakes/Hydraulic Systems
Jun 26, 2013 08:21 AM
