looking for hyrdoboost brake kit
Old February 3rd, 2013, 05:21 PM
dynamic88371's Avatar
hey guys i remember comin across a hydroboost kit to convert from drum to disk on all four and now i cant remember the company and i cant find it but i remember it was some 1600$ for it
its for my 60 olds 88
dynamic88371 is offline
Old February 3rd, 2013, 06:14 PM
keepitolds's Avatar
Try inline tube.com
keepitolds is offline
Old February 4th, 2013, 07:03 AM
What kind of kit are you looking for, and why do you want a hydroboost? While the hydroboost works fine, it is not necessary for a disc conversion - a normal vacuum booster works. It's the master cylinder that matters.
Keep in mind that a hydroboost operates off the power steering pump, so you need to change the pump and reservoir to hook it up properly. If you have fabrication skills, every one ton Chevy/GMC pickup has a hydroboost system that you can get for cheap at a wrecking yard. You'll likely need to fabricate an adapter plate to mount it on your firewall. Use a Corvette disc/disc master cylinder.
joe_padavano is online now
Old February 4th, 2013, 10:09 AM
well the car is not going to be stock for long thinking about getting a caddy 500 for it so really want stoping power and dont want a vac booster in the way and cluter up under the hood
gejackson
Brakes/Hydraulic Systems
August 10th, 2016 07:21 AM
HIGHCOMP425
December 20th, 2011 07:19 PM
jeffu231
July 15th, 2009 07:51 PM
citcapp
April 3rd, 2009 03:20 PM
Satellitecentral
17
February 22nd, 2009 04:00 PM
Quick Reply: looking for hyrdoboost brake kit
