Hydro boost brakes
Old Apr 5, 2015 | 07:29 AM
ioldsnut's Avatar
Hydro boost brakes
Any one using a hydro boost system on their Olds? If so, please explain who's and what your using? I know there are Wilwood kits out there but I was wondering if someone has come up with something less expensive?
Maybe someone is using something else for brake assist? Just checking the waters out there....
Thanks,Reggie
Old Apr 5, 2015 | 07:51 AM
You can just get these from diesel vehicles in the junkyard for a reasonable price.
You can then mess around with repainting, chrome plating, new hoses, etc. as much or as little as you'd like.
Old Apr 5, 2015 | 07:53 AM
The aftermarket hydroboost is the same one that GM used on every one-ton pickup and on diesel Oldsmobiles. You'll need to fabricate a bracket to mount it to the firewall, but you can then bolt up your regular master cylinder. Get the Saginaw PS pump from the truck as well - it will bolt to the Olds PS pump brackets. You will likely need custom hoses, as the truck ones are likely too long.
Old Apr 5, 2015 | 08:12 AM
ioldsnut's Avatar
I have a 2004 Chevy Avalanche and just went outside to see what it has... Lo and behold,,, hydro-boost...lol... Not sure how to make that work,,, but interesting...
Old Apr 5, 2015 | 09:20 AM
Stevec's Avatar
Cpp has a hydro boost brake kit..
Old Apr 5, 2015 | 01:40 PM
bob p's Avatar
Rocketeer
I've been thinking about doing a PS + hydroboost setup for one of my other cars. Rather than buying a new aftermarket setup you might consider a remanufactured system. I'd go looking for a core at the parts yard, as the core charge for the reman units can be pretty high. Look at Astro vans and 3/4 ton trucks.
Old Apr 5, 2015 | 02:27 PM
ioldsnut's Avatar
Bobp,, I have some friends who have done hydro boost, but have bought kits $$$.... I'm with you, there has to be a cheaper way...
Old Apr 5, 2015 | 02:50 PM
oldsmobiledave's Avatar
Fyi
Hydro boost on my 1980 GMC and on my 1987 442. The track is factory and the g body is Wilwood. Both work flawlessly.
Old Apr 5, 2015 | 05:18 PM
ioldsnut's Avatar
Tell us how Dave,,, Tell us!
Old Apr 5, 2015 | 10:37 PM
Not sure I understand. The 80 GMC was a diesel so all the hydro boost was stock GM. The Wilwood kit is pretty common as an upgrade when adding 4 wheel disc brakes. Not sure what else to say other than one never has to worry about low vacuum and high lift cams.
Old Apr 6, 2015 | 07:28 AM
Oldsmobile used hydroboost on diesel powered cars from the factory. I pulled one off a diesel Cutlass in a wrecking yard years ago. For that matter, you can probably use the hoses for one of these on a hydroboost in an earlier car. RockAuto sells rebuilt hydrobooster units and hoses for these applications.
Old Apr 7, 2015 | 04:30 AM
ioldsnut's Avatar
I'll check into that Joe... Thanks
Jim w
Dec 28, 2010 05:20 AM
ELECMAN
Aug 31, 2010 08:26 PM
nuttkaze
Jun 12, 2010 03:12 PM
455islove
Oct 10, 2009 09:30 PM
cfair
Sep 13, 2009 05:00 AM
