help: 1970 brake booster and master cylinder codes?
Old Mar 13, 2011 | 07:00 PM
virtualwsp's Avatar
I am looking to restore the brake booster and master cylinder on my 1970 442. I need help to determine if my part is original.
What is the correct codes for the brake booster and master cylinder? I understand there is a julian date code on the front top tab of the booster but what is the correct code on the back of that tab?
For the master cylinder what is the correct codes that should be found on it? I understand there is a part number and build date under underside. What should it be and are there any other codes that I should check for?
Any information is appreciated. Thanks in advance.
Old Jun 13, 2012 | 02:00 PM
Del70's Avatar
would like to verify the codes as well. In the assembly manual, for a 70 power drum it shows TN for the master cylinder and UB for the booster assembly. I assume these are correct….anyone know for sure, if these are the code that should be on the tags?. thanks
Paaro
Tech Editor's Desk
Jul 30, 2015 06:16 AM
Paaro
Jun 29, 2015 04:51 AM
Finn5033
Brakes/Hydraulic Systems
19
Apr 25, 2013 01:25 PM
98 man
Jan 7, 2013 04:31 PM
66-3X2 442
Sep 22, 2011 07:53 PM
