Going Hydroboost on the 69 442
Old Dec 16, 2018 | 11:56 AM
Big Dawg's Avatar
Okay so I have decided to go Hydroboost on my 69 442. The brakes just were not performing to my liking. The cam in the 468 olds just isn't creating enough vacuum for the brake booster. Can not even make the brakes lock up and the pedal is so soft, even after bleeding the entire system 3 times.
I got my hands on a hydroboost setup out of a 95 astro van, my question is does anyone know off hand what the fitting sizes are on the power steering pump and the gear box?
Thanks again guys!
Old Dec 16, 2018 | 12:09 PM
First of all, if the pedal is soft, the booster is not your problem. A lack of boost will give you a rock hard pedal that won't move. Bleed the rest of the air out of the system before spending any money on new parts.
Old Dec 16, 2018 | 03:01 PM
classicmuscle442's Avatar
This^^^, soft pedal means you still have air in system. If you still have the old rubber lines that could be the problem. Just posted a thread with pictures of the old restricted hoses.
Bfg
Aug 22, 2019 08:33 AM
Mark71
Brakes/Hydraulic Systems
23
Jul 25, 2016 12:45 PM
Rocketbrian
Nov 30, 2015 04:02 PM
willj
Apr 27, 2014 03:15 PM
scrappie
Sep 18, 2012 07:54 AM
