gasket between master and booster?
Old June 24th, 2017, 08:32 AM
alexrains's Avatar
Can somebody please enlighten me on the existence of a gasket between the master cylinder and the brake booster on a 1966 442?
Engine idles slightly (!) rougher, when not stepping hard on the brake (then perfect).
All vacuum lines are definitely tight but there could be a loss, as master and booster just "sit" metal on metal.
Thx, Alex.
alexrains is offline
Old June 24th, 2017, 08:45 AM
I believe there is generally a paper gasket between the booster and the firewall, but no gasket between the m/c and the booster.
MDchanic is offline
Old June 24th, 2017, 08:54 AM
Actually, there is, and it does seal the front vacuum chamber of the booster. This seal is very difficult to get. The only sources for new ones I've found are the Corvette repro houses, and thus they are priced accordingly.
Note that there are two styles, depending on year, the flat ones and the cupped ones.
joe_padavano is online now
Old June 24th, 2017, 09:13 AM
I was thinking of a flat gasket between the two mating flanges - guess I was thinking too narrowly.
MDchanic is offline
Old June 24th, 2017, 09:14 AM
Nope just the cup.
oldcutlass is offline
Old June 24th, 2017, 09:17 AM
alexrains's Avatar
Eric: that was my mechanic's opinion also, but the "hard on brake thing" made me think.
Joe: will order all, as it gets on my nerves and shipping to my country takes ages...
Thank you both! Really appreciate how fast this forum is.
Old June 24th, 2017, 12:19 PM
jfb
jfb's Avatar
I experienced this myself so maybe you should check it also. check around the area when the car is running and I mean the master to vacuum booster for a vacuum leak the booster might be bad. I went through this before on mine. check with a vacuum gauge also for fluctuations of vacuum levels.
jfb is offline
Old June 24th, 2017, 12:53 PM
I just changed my booster because it was leaking. When I pulled it out I found that the assembly had broken on the rear allowing the push rod to flop around inside the power booster that created a small leak. Push on the pedal and the engine would drop 200 rpm, release and they went back up.
Oldssupreme
August 17th, 2016 05:05 PM
Rustbucket2
Brakes/Hydraulic Systems
March 11th, 2016 07:11 AM
CyberCholo
19
April 12th, 2014 12:09 PM
w31man
January 7th, 2013 04:31 PM
virtualwsp
June 13th, 2012 02:00 PM
Quick Reply: gasket between master and booster?
