4 wheel power drum brakes, pedal goes away out of the blue.
Old Jun 25, 2017 | 09:04 PM
olds 307 and 403's Avatar
Out of Line, Everytime😉
I thought it was the heavy rain, the brakes went nearly to the floor, has gone a hence my fixing the emergency brake. I kind of have the same issue as Copper had. I redid all the brake shoes, replaced both front wheel cylinders and one brake hose and bled the brakes with my daughter. Could it just need rebled or a dying master cylinder? Just weird that is only soft at times.
Old Jun 25, 2017 | 09:10 PM
coppercutlass's Avatar
Chevy budget Olds powered
I will say my bleeding issues where bad parts one after the other., My weak brakes are a vacuum issue. Not enough and i get only one solid pump under really light loads and a few pumps under heavy deceleration when vacuum is the highest . I did add a vacuum canister and it helped. I will be going to manual soon.
Do some stress testing in a parking lot and see what makes you loose them like many pumps of the pedal / slow mph braking etc etc.
Old Jun 26, 2017 | 05:24 AM
Vacuum should not be my issue and the brakes should be set right. Under the heavy rain, that was probably water. The pedal just goes soft on occasion and can be pumped back up.
Old Jun 26, 2017 | 06:27 AM
If it can be pumped back up there is air in the lines.
Old Jun 26, 2017 | 07:35 AM
Or, it's an internal leak in the M/C. I've had this happen where the M/C intermediate seal went bad and fluid from the front reservoir would flow into the rear reservoir instead of to the wheels.
Old Jun 26, 2017 | 09:34 AM
I have also, but it would do it all the time and not pump up.
Old Jun 29, 2017 | 10:08 PM
Thanks, I have had a master cylinder go bad before on a Dodge van, stayed funky. It can be good 20 times in row, then bang a soft pedal. Yes, I did try pumping it up and the pedal was normal in a couple of pumps.
RocketV8
Brakes/Hydraulic Systems
28
Jun 13, 2023 11:34 AM
Supernaut72
31
Mar 2, 2017 03:24 AM
Bikerman883
Oct 19, 2015 07:25 AM
455Olds
Dec 8, 2013 08:16 PM
1carsick
23
Oct 2, 2012 05:50 PM
