Front Drum brakes grinding noise
Old Oct 20, 2019 | 03:57 AM
71OldscutlassS's Avatar
Hello everyone,
I have a 1971 CS with power drums front and rear.
The brakes are all new, wheel cylinders, shoes, small hardware parts, drums, all lines and the distribution block.
Wheel bearings are new too.
Since the car was pulling to the left while braking, i tried to adjust the front drum brakes and made sure that the self adjusters do their job.
BUT... after a few adjustments (which havent made a big difference) my left front brake makes a odd grinding noise when braking a bit harder. So i took the drum off and figured out, that the metal on the lower side of the shoe was grinding on the inside of the drum. How can this be with new bearings, cause this tells me that my left hub is too close to the brake.
My front drums are finest chinesium from RockAuto.
Im not sure if the drums are the problem, because this problem started AFTER some shoe-adjustments. Before, it wasnt grinding.
Thanks for any ideas, i hope i was able to explain the problem good enough!
Greetings from Austria!
Old Oct 20, 2019 | 05:20 AM
classicmuscle442's Avatar
Could you have the wrong width of brake shoes?
Old Oct 20, 2019 | 06:58 AM
Look to see how you put it together, if you had the wrong part it should be doing it on both sides. Compare the right to the left and see if there are any differences. Post some pictures.
Old Oct 20, 2019 | 07:28 AM
FN723's Avatar
When ever I have issues with a vehicle pulling to one side when braking the issue was with a loose wheel bearing.
Old Oct 20, 2019 | 08:24 AM
BackInTheGame's Avatar
Check whether you have the correct placement of Primary and Secondary shoes, and the correct color spring holding them down.
Old Oct 21, 2019 | 09:57 AM
Ok, ill take dome pictures next time i work on the car!
Wheel bearings are all new and snug.
Thank you for the input!
Old Oct 21, 2019 | 04:06 PM
Sugar Bear's Avatar
For diagnostic purposes, swap drums side to side and see if it follows the drum or stays on the same side.
Good luck!!!
Old Nov 26, 2019 | 08:50 AM
Here are a few pictures of the grinding left front brake, the spots i marked yellow are the spots where its grinding when braking a bit firmer:
Maybe just grinding the metal off the brake shoe?
On Passenger side, everything is ok.
Drums, brake shoes, wheel bearings and hardware are all new.
maybe you guys have some ideas?
Old Nov 26, 2019 | 09:00 AM
JohnnyBs68S's Avatar
Is it possible that there is something on the backing plate where that shoe rubs that is pushing it outward? Or could the backing plate be bent outwards a bit there to cause an interference between the shoe and drum?
I second the idea of swapping drums from side-to-side to exonerate either the drum or the brake assembly.
Old Nov 26, 2019 | 09:39 AM
thanks a lot for the ideas! Im going to check that.
its true, i painted the backing plates with a good layer of rust protection paint. Maybe this pushes the shoes a bit too far to the drums.
Old Nov 26, 2019 | 09:55 AM
droldsmorland's Avatar
CH3NO2 LEARN IT BURN IT
Inspect the depth of the groove in the drum that interacts with the backing plate. Chances are it's not cut to spec (shocker) and rubbing on the backing plate? Ask how I know this one.
Root Cause...Chineasium JUNK cast from rusted scrap cut by a 5-year-old with a missing arm on a worn-out lathe from WWII out in a field belt-driven by a 3600 rpm yard tractor up on blocks with one wheel turned into a sheave!
Old Nov 26, 2019 | 10:06 AM
You can take a file to the metal on the side of the shoe/s or take the drum to an auto parts store with a lathe and have that area on the drum clearance.
Old Nov 26, 2019 | 11:08 AM
haha nice story of how chinesium drums are made
but its definitely not rubbing on the backing plate. Its the metal of the shoes (shoes are Federal Mogul).
I think im gonna file/grind the metal of the shoes a bit off, it stands a bit over the pad itself and try it out.
Thank you all!
Old Nov 26, 2019 | 02:08 PM
Could spindle be worn, allowing hub / bearings to slide on a bit to far.
Old Nov 26, 2019 | 02:31 PM
Yellowstatue's Avatar
Are the shoes 2 inches wide or 2 1/2. Rear shoes on the front?
Old Nov 26, 2019 | 04:49 PM
Those shoes do look a bit wide.
Old Nov 27, 2019 | 02:37 AM
The front shoes are 2 1/2, got it from Rockauto and they list all front shoes 2 1/2 for this car, but i gonna measure them.
Old Nov 27, 2019 | 05:28 AM
Never saw that before... I think it maybe that backing plates are bent or missaligned?? Let us know what you find!
Old Nov 27, 2019 | 09:10 AM
My backing plates are fine. Ive just measured the the shoes. The pad itself is 63mm wide, which is 2 1/2 inches. BUT, the Metal of the shoes is 65mm wide, and the metal is the part which is grinding in the drum. So i think Federal Mogul is chinesium too .
I will grind the overstanding metal off to make it clear to the pads itself and give it a try.
Old Nov 27, 2019 | 10:33 AM
Now i disassembled both front brakes, scrapes the paint off the "sliding points" of the backing plate (the was a lot of Paint on those points, i hope this helps to get a better clearence too) and grinded the overstanding metal off the shoes. Next few days im gonna take the car for a test ride.
Old Dec 31, 2023 | 01:57 AM
Del70's Avatar
Old thread I know - I assume you resolved this issue long ago by grinding the shoe backing plate down or tossing the drum out and getting another drum or brand?
Old Dec 31, 2023 | 02:17 AM
Issue solved long ago by converting the car to front disc brakes from a 71 chevelle.
But back then, what i did with some clearancing on the brake shoes and scraping off the paint on the points of the plate where the shoes lie, solved the issue with the drum brakes too.
Old Dec 31, 2023 | 04:19 AM
Del70's Avatar
Converting to disc seems to be the solution, thanks..
Old Dec 31, 2023 | 04:51 AM
The conversion is really easy to do and a huge improvement over front drums. I used all used GM original parts to make sure i can re-use my 14 inch rally wheels. cleaned them up + painted them.
If i remember corretly, you basically need:
- disc brake spindles from any GM A Body car - 72
- the calipers + mounting brackets + maybe a caliper rebuilt kit
- the "dust plates"
- new stock style brake discs
- new brake pads
- new front rubber brake lines
- correct disc/drum brake distributor valve
- correct disc/drum master brake cylinder
- and for sure, some brake lines + flared nuts to do the plumbing with the new master cylinder/distributor valve.
Old Dec 31, 2023 | 12:42 PM
Del70's Avatar
Thanks.
Old Jan 1, 2024 | 01:42 AM
Sorry, but this is BS. The brakes did not rub or grind when the car left the factory. Spending $1000 to fix something that should not be a problem in the first place is just kidding yourself. No, I'm not suggesting that the disks aren't a better braking system, but frankly, if one can't find the cause of a simple problem like this, one's ability to correctly do a disc brake swap comes into question. And once again, nearly EVERY aftermarket disc brake kit is poorly designed. Go read the other thread where a simple thing like the bracket to hold the combo valve doesn't fit on a conversion that is being done.
71OldscutlassS
Brakes/Hydraulic Systems
Oct 14, 2019 07:57 AM
Gpc1
Sep 17, 2019 09:14 AM
DTencza
Sep 6, 2019 04:45 PM
1969cutlass4d
Apr 21, 2015 06:09 AM
dewcrazzy
Mar 25, 2013 07:51 PM
