Front Drum Brake Question for 1965 442
Old February 24th, 2018, 05:18 PM
Big Daddy Spo's Avatar
Just starting to tear into this project, so I wanted to get the brakes dialed in. I removed the drum and hub as a unit. I see that most auto parts places sell the drums and have found some that sell the hub assembly. My questions is to remove the hub from the drum: Do you push out the lugs to unlock the hub from the drum or do you push the complete hub (from the center) to release it from the drum? Here a a few photos of the assembly. Thanks for the help.
Steve
Big Daddy Spo is offline
Old February 24th, 2018, 05:19 PM
2blu442's Avatar
Push out the studs, then the hub should come off easily.
John
2blu442 is offline
Old February 24th, 2018, 05:39 PM
Great! Thanks for the info. One drum looks like it can be turned the other was down to rivets. I will replace both drums as the hubs look good. Installation of the new drums is the same? Just push the lugs back into the new drum? Thanks.
Old February 24th, 2018, 05:45 PM
2blu442's Avatar
Yes, the studs have splines in them as you press them in they should fit tight.
2blu442 is offline
Old February 24th, 2018, 05:55 PM
Will do. Thanks again for the help.
Steve
matviar
October 22nd, 2014 11:12 PM
yeahbuddy
Brakes/Hydraulic Systems
January 15th, 2014 02:10 PM
455Olds
December 8th, 2013 08:16 PM
1969cutlazz
21
January 7th, 2013 05:08 AM
501Paratrooper
June 20th, 2012 11:35 AM
Quick Reply: Front Drum Brake Question for 1965 442
