front brakes on a 72 cutlass
Old Dec 26, 2011 | 02:44 PM
mdfedewa's Avatar
does a 72 cutlass have disc brakes and are they power? i want to change the rear to disc also will iu have to change the booster?
Old Dec 26, 2011 | 03:00 PM
svnt442's Avatar
Well disc brakes are an option. You'll have to look to see if the car has them or not. Power was also an option. If the car has a booster then it has power brakes.
Old Dec 27, 2011 | 06:29 AM
mdfedewa's Avatar
It does have a booster. I want rear disc brakes also
Old Dec 27, 2011 | 02:27 PM
svnt442's Avatar
Well then I think you need to look at aftermarket brakes all the way around.
Old Dec 27, 2011 | 02:30 PM
kitfoxdave's Avatar
And most likely bigger wheels.... at least 15" from what I have seen...
Old Dec 27, 2011 | 03:01 PM
From the factory, earlier 72 production was drum, all the later production is power disc brakes. The rear drums stayed as convential drum brakes until the 90's when all wheel disc and ABS came in.
If you're changing over your car from drums? Yes you'll need to change the proportioning valve. If you already have an 11" booster for disc brakes on the car, I don't know if it needs to be changed or not.
Gearheads78, 507OLDS or Joe Padevano could probably steer you in the right direction
DR_DAN
Mar 9, 2015 05:48 PM
72allblackcoupe
Apr 6, 2014 07:20 PM
1carsick
Brakes/Hydraulic Systems
23
Oct 2, 2012 05:50 PM
russell-t
Apr 30, 2011 05:56 AM
Supreme
Aug 11, 2004 06:58 PM
