enough for disc conv
Old Mar 12, 2009 | 05:50 AM
olds4life's Avatar
hey olds nation!!!!! i have a gentleman wanting to sell me the following parts for a disc brake conversion from a 69 442: a arms, spindles, rotors, powerbrake boster just like they were unbolteted from frame. do i need the a arms to convert. what about the backing plates and the caliper brackets. he is asking $200.00 thanks
Old Mar 12, 2009 | 06:37 AM
csstrux's Avatar
I'm not 100% but think all you will need is from the spindle out, and a proper proportioning valve. the A arms would just be a bonus. Assuming this is accurate, I'd jump on it.
Old Mar 12, 2009 | 07:32 AM
Correct. The minimum list of parts you need is:
Spindles
Caliper brackets
Calipers
Rotors
Brake hoses
Brake hose brackets on frame
Master cylinder
Proportioning valve
Old Mar 13, 2009 | 08:16 AM
rockethound's Avatar
that is write all you need is the spindles caliper brackets calipers hose brackets proportioning valve and master cylinder that is what i paid for mine a few years ago.
i have disc brakes off of a 70 it had a one piston caliper instead of the 68 that had 2 piston calipers. actually i think i have another set from a 68 442 just the spindles rotors backing plates caliper brackets and just one caliper i don't have the prop. valve or master
i'll have to look
Old Mar 13, 2009 | 12:55 PM
i'll have to look
The 67-68 cars had FOUR piston calipers (two per side of the caliper) that were fixed. These were very sensitive to rotor warpage, which is why GM changed to the sliding single piston design in 1969. Either design works on any 64-72 A-body, however the four piston systems are 1) sought after by restorers and 2) more difficult to get parts for.
Old Mar 13, 2009 | 04:27 PM
ya i found the 70 disc set up first then paid 400 for a 68 442 basket case that had the disc brakes. i forgot i had those sitting around. the guy i got the car from was a basket case as well. i'll have to tell that story some time.
allyolds68
Feb 9, 2013 08:01 PM
Texas Jim
Feb 5, 2010 07:25 AM
Steeb
Feb 19, 2009 11:15 PM
esisson
Nov 19, 2008 10:40 AM
http
Mar 8, 2008 03:03 PM
