emergency cable '84 Delta 88
Old Feb 12, 2007 | 04:14 PM
ztim's Avatar
Is there a special tool for replaceing the cable. It is frozen solid and won't move at all. Or, should I have a shop do it?
Old Feb 23, 2007 | 12:47 AM
ztim's Avatar
Good question Ztim. I don't know the answer, so you will have to leave it to the forum members.
Old Feb 26, 2007 | 04:35 AM
Jim's rare 80's Avatar
Jim's rare 80
No special tools required, just patience. After you check to see if the rears are siezed or not, cut the old cable where it connects to the intermediate, under the driver's floor, or loosen the equalizer nut (where it splits at the rear) if it's not too rusted. A spring clip holds it in the frame, (remove first) and a rubber grommet at the firewall. The cable is removed from inside the car. Tie a string, or wire to the old one before removal, it will help in feeding through the new one. Hope this helps.
Olds442redberet
Aug 13, 2015 08:23 PM
widowmaker1201
Dec 2, 2012 01:27 PM
CUT-N-UP
Jul 10, 2011 03:53 PM
Chesrown 67 OAI
Brakes/Hydraulic Systems
25
May 17, 2011 08:24 AM
GoodOldsGuyDougie
May 14, 2010 11:50 AM
