Dual master cylinder question
I have 66 vista cruiser. Would like to upgrade to dual master cylinder. I have used 70s gm disc, drum master on other cars with proportioning valve. Will this work with stock brake booster. Doing motor change this winter and would to do while motor is out. Will add the front add the front disc at later date.
Your 66 power booster uses a long pushrod to the M/C, so you need an M/C with a deep hole. The M/C for a 1962-66 Cadillac is a readily available dual circuit M/C for drum/drum cars that bolts to your booster. It will not work with front discs when you get there.
Welcome. It is not in your best interest to post the same question in multiple forums. A single thread keeps all responses in one place so incorrect info can be identified and corrected.
Sleepybeaver
Brakes/Hydraulic Systems
Nov 7, 2016 12:29 PM
arcee1951
Mar 1, 2016 06:05 AM
