dual master cylinder
Old Jun 7, 2014 | 11:00 AM
Tedisthebestkingintheworl's Avatar
I want to put a dual master cylinder on my 1966 Cutlass convertible. Does anyone know what the easiest match of cylinder and proportioning valves would be right off hand?
Old Jun 7, 2014 | 11:02 AM
2blu442's Avatar
The 1967 Cutlass used a dual master cylinder. I'd just replace what you have with 1967 parts.
John
Old Jun 7, 2014 | 11:24 AM
First, cars with four wheel drum brakes do not use a proportioning valve. Second, as noted, just use the 1967 parts. The dual circuit M/C requires a shorter pushrod from the booster to the M/C, so you can't simply bolt one to your current booster. Inline Tube sells the shorter pushrod, but you have to disassemble the booster to install it. The easiest thing is to just get a 1967-72 booster and a 67 M/C. For drum brakes, you'll need a distribution block, which is NOT a proportioning valve.
Old Jun 7, 2014 | 08:13 PM
Run to Rund's Avatar
If manual brakes, use the inline tube INL12439 derby hat shaped retainer so the pushrod can't fall out of the master cylinder.
1Fastolds
Ninety-Eight
Jun 9, 2014 09:12 PM
twintracks
Brakes/Hydraulic Systems
Mar 15, 2014 11:09 AM
bobfo1
May 25, 2012 09:04 PM
CutlassLegend
Aug 7, 2011 05:15 PM
martine
Feb 5, 2004 10:28 AM
