Dual brake system finally!
Old May 17, 2017 | 05:52 PM
Vistabrat72's Avatar
Good evening to the forum. In the interest of safety on the crowded roads going too and from classic car shows, we decided to have our 1966 Olds Ninety Eight converted from a single to a dual master cylinder setup. Thanks to Joe Padavano for saying it was not simply swapping in a 1967 and up master cylinder, due to push rod lengths. And what cylinder should be used, but not proven yet in the field. I am happy to say the suggested 1966 Cadillac master cylinder (Cadillac switched to a dual master cylinder in 1962) fit like a glove, and we now have a dual braking system on our car. Then original lines on the car are in new shape and were able to be bent to fit the new cylinder, the shop only needed a 6-inch extension to complete the circuit to the rear brakes. I know it does not look factory squeaky clean, but safety is a priority. The part number for the cylinder is M36373, from a company called Pronto. Dorman seems to have the same number too. I hope this helps to save many headaches from happening to those wishing to switch with minimal fuss.
The new dual master cylinder part number M36373
Old May 19, 2017 | 11:04 AM
D. Yaros's Avatar
Good info! Am curious, did this dual MC require a different push rod?
Old May 19, 2017 | 11:37 AM
It should not. The early Caddy dual M/C had a deep pushrod hole in the rear piston that accepts the long booster pushrod.
Old May 19, 2017 | 01:37 PM
Thank you D. Yaros, I hope this helps others. Proof positive what Joe said, it was a perfect fit. I did notice when we did a quick trial fit before we took the car to the garage (We were able to move the original cylinder forward, attached to the line, out of the way) my push rod is the adjustable type. Nothing had to be altered or readjusted.
Old May 20, 2017 | 11:12 AM
D. Yaros's Avatar
Joe P. - So, the question for me becomes: Will the 62 Caddy dual MC bolt up and work without other mods on my 1962 Olds Dynamic 88?
Old May 20, 2017 | 12:11 PM
Yes, the Caddy M/C has the deep hole needed for the long pushrod on the 62 booster. Note that the Caddy M/C has outlet ports on the passenger side, but you'll need to replumb anyway, so that shouldn't be a big deal. And the P/N is the same for 1962-66. It's a 1" bore M/C.
Old May 22, 2017 | 12:19 PM
D. Yaros's Avatar
I thank you. Pleased to have this info. Have searched the web and found that the 1962 Cad MC is readily available at reasonable cost.
Old Sep 10, 2018 | 06:23 AM
6262's Avatar
Does the '62 to '66 Cadillac dual circuit master cylinder also fit the '60 Oldsmobile Dynamic 88?
Thanks!
Old Sep 10, 2018 | 07:10 AM
Thanks!
Unfortunately not. The piston for the master cylinder is integral with the booster on your car. You cannot retrofit a different M/C to that booster. You'll need to change both booster and M/C.
Old Sep 10, 2018 | 07:17 AM
6262's Avatar
Okay, thanks for the quick answer. Is there any master/booster combination that "plugs right in" (lines exempted)?
Old Sep 10, 2018 | 08:01 PM
Charlie Jones's Avatar
Phantom Phixer
It will if it's a Moraine cylinder . (2 bolts)
It won't if it's a Bendix . (4 bolts)
Old Sep 10, 2018 | 10:11 PM
6262's Avatar
Thank you, Charlie!
Is this also true for the '60 Dynamic 88?
Old Sep 11, 2018 | 12:59 PM
Phantom Phixer
Thank you, Charlie!
No , 1953 thru 1960 Oldsmobiles with power brakes , had a Treadle-Vac booster and master cylinder unit .
They mounted under the floor and were quite different from conventional "pendilum pedal " setups on later cars .
These cars have been successfully converted to "modern" dual-master setups . As evidenced by this thread here ;
https://classicoldsmobile.com/forums...1955-olds.html
It all depends on your fabrication skills or the depth of your pockets .
Old Sep 11, 2018 | 11:27 PM
6262's Avatar
Thanks for sharing your knowledge. Very helpful!
Fox Stuart
Brakes/Hydraulic Systems
May 31, 2017 11:08 AM
arcee1951
Mar 1, 2016 06:05 AM
Tedisthebestkingintheworl
Jun 7, 2014 08:13 PM
bobfo1
May 25, 2012 09:04 PM
martine
Feb 5, 2004 10:28 AM
