drum to disc with separate hub
Old Dec 27, 2020 | 08:03 AM
jarcher442's Avatar
This might have been covered elsewhere but I could not find it. Here goes. 1967 442 that previous owner swapped one piece drum and hub for separate drum and hub. I am converting to disc with set up from a 1970 Cutlass. It has a one piece hub and rotor. Can I use the separate hub with a separate rotor I would assume with longer studs. I prefer the advantage of removing the rotor without disturbing the bearings. If so what rotor application do I get? These hubs are only a year old (so brand new) and would like to retain them also for the advantage. Parts I have The upper row is the drum set up off my car and the lower row is the disc set up.
Old Dec 27, 2020 | 12:44 PM
Use the correct rotors for the spindles and calipers, which are the one-piece rotors. There are no "slip on" rotors for this application. The factory two piece rotors were held together by the pressed-in wheel studs anyway - the rotors didn't "slip off". And frankly, any time the rotors need to come off, you should repack the front wheel bearings anyway (if not more frequently).
Alex72cutty
Brakes/Hydraulic Systems
16
Sep 1, 2017 07:59 AM
72oldspa
Apr 8, 2014 11:13 AM
olds330
Mar 17, 2014 10:21 AM
1969cutlazz
21
Jan 7, 2013 05:08 AM
jerseyjoe
Jan 4, 2011 06:54 PM
