Drum Brake Spring Color/Location
Old August 24th, 2017, 05:42 PM
tgilligan's Avatar
Hi All,
Redoing my shoes, hardware and wheel cylinders in my 70' CS. Drum brakes all around and picked up hardware kits from local auto parts. Is there a diagram to show what color goes where? My existing is either severely rusted or missing and I want to make sure I have proper placement. The kit for the front came with 2 gold/yellow, 2 green, handful of white and new retainers, rods, etc. most of it I was able to match up by size and fit but the side shoe springs and retainers I question. Is it one yellow and one green pet wheel?
tgilligan is offline
Old August 24th, 2017, 09:45 PM
jaunty75's Avatar
I don't think there's any rhyme or reason to the colors of the springs in these kits. At least, I've never heard that there weas. I've seen kits with colored springs and kits without, and the colors aren't always consistent for the kits with color springs. What you need is the service manual for your car with a good image of a fully-assembled drum brake.
I redid the rear brakes on my '78 Toronado earlier this year, and I took some before/after photos. Here's the left side before. The springs are not colored, or, if they ever were, the color is long gone.
Here's the same brake after all the springs, shoes, etc. were replaced. One large spring was orange, the other no color at all, and the small one was white. The size and shape of the spring will tell you where it goes as there is only one place for each of them.
jaunty75 is offline
Old August 25th, 2017, 02:40 AM
Its easier if you do one wheel at a time start to finish so you can use the opposite side as a mirror image in case you get stuck.
oldcutlass is online now
Old August 25th, 2017, 06:20 AM
Originally Posted by tgilligan
Hi All,
The colors are not standard. Different kit manufacturers use different colors. The springs only fit in one place. Usually you would simply match the new ones to the old ones when you take them off.
joe_padavano is offline
Run to Rund's Avatar
Also, there are drawings in the chassis service manual. However, the photos above should be clear enough, and as above, don't worry about the colors. The sizes and lengths are different enough that their positions are clear.
Run to Rund is offline
Old August 25th, 2017, 09:48 AM
JohnnyBs68S's Avatar
That's exactly the method I used the first time I did brakes on dad's '66 Impala wagon..............when I was 10 years old.
JohnnyBs68S is offline
Old August 25th, 2017, 10:58 AM
I actually still do it, I have a bad case of crs...
johns59super88
August 5th, 2016 03:06 PM
Kilmster
Brakes/Hydraulic Systems
August 6th, 2014 05:41 PM
yeahbuddy
January 15th, 2014 02:10 PM
Mark71
May 24th, 2011 07:11 PM
jon69olds
Wheels and Tires
February 11th, 2011 11:57 AM
Quick Reply: Drum Brake Spring Color/Location
