Dot 5 replacing Dot 3?
Old Jul 28, 2023 | 07:14 AM
olds 307 and 403's Avatar
Out of Line, Everytime😉
The system has to be completely flushed, correct? Is it true once Dot 3 is in a system, Dot 5 can't be used due to incompatibility with seals? Or is it Dot 5 needs special components? My 70S sits for 6 months of the year. Thoughts or experiences are welcome.
Old Jul 28, 2023 | 08:12 AM
I've swapped to DOT 5 without doing anything special and had no problems. Today I use DOT 5.1, which is compatible with 3.0 and 4.0.
Old Jul 28, 2023 | 08:22 AM
VC455's Avatar
Barely Registered
I changed to DOT 5 when I rebuilt my brake system about 15 years ago. That was a good time, as all the DOT 3 was out of the system. When the lines were disconnected, I flushed them with water and then isopropyl alcohol, and used compressed air a few times to make sure they were dry. I used stock seals.
Bleeding was the hardest thing to do. DOT 5 is prone to getting aerated easily.
I tried vacuum bleeding, then pressure bleeding, but finally realized that any rapid movement of the DOT 5 causes air bubbles.
I eventually settled on gravity bleeding. The fronts bled in a few hours, but the rears took a while longer. I raised the front end a few inches to give more pressure, and bleeding completed in about 4 more hours.
I put a clear tube on the bleed screws, so I could see if all the air was out.
I've never had any problem in the subsequent years, except for a minor leak at the distribution tee on the rear axle. It's easier to add an ounce every few years than to put a copper crush washer on the leaky joint. And that also makes sure I remember to check the MC level.
Old Jul 28, 2023 | 08:34 AM
Yeah, I like the non moisture absorbing of the Dot 5. I don't see any advantages for Dot 5.1. What do you mean by nothing special? I had a bitch of a time when I put new Nicopper lines on the back and needed to use a pressure bleeder. There are fairly new wheel cylinders all on all 4 corners.
Old Jul 28, 2023 | 11:00 AM
Run to Rund's Avatar
Brake fluids were deliberately designed to absorb water. Humidity will get into the system and water puddles won't perform well.
Old Jul 30, 2023 | 08:12 AM
Good point, I was thinking of that as well. I may just leave it with DOT 3, it has pretty fresh fluid.
Old Jul 30, 2023 | 11:07 AM
If, as you say, the car sits for long periods, you might consider DOT 5 for its non-hygroscopic properties. I have it in my summer-only cars and have had no problems with aeration or air bubbles.
Leadfoot
Jun 13, 2024 06:24 AM
truckman5000
Jun 25, 2016 03:43 PM
72allblackcoupe
Apr 7, 2014 07:52 AM
mmurphy77
May 17, 2013 06:53 AM
hurstman1972
Aug 14, 2012 06:46 AM
