Disk conversion; can I use the drum booster?
Old December 29th, 2014, 08:15 AM
Mostly Gristle
bluecab's Avatar
Here are the details,
On my '66 Toro I have assembled all the parts for a disk conversion using 1969/1970 parts.
I bought a MC that is right for the caliper/drum setup but did not buy a booster at the time.
Will I need a later booster to make the system work properly?
What is the difference between the various boosters? Amount of boost? Pedal travel?
I have never done any work on this part of a brake system before so my experience is nil and my knowledge of the theory of operation is about the same...
bluecab is offline
Old December 29th, 2014, 10:16 AM
The difference is the length of the pushrod between the booster and the M/C. 1966-earlier cars with single circuit brakes used a longer pushrod than cars with dual circuit brakes. Compare the depth of the hole in the end of the piston on the new and old M/Cs and you'll see the difference. It is possible to change the pushrod or cut it down, but I believe this requires the booster to be disassembled.
joe_padavano is offline
delmontcrusier
May 28th, 2023 07:37 AM
455Olds
Brakes/Hydraulic Systems
December 8th, 2013 08:16 PM
Troys Toy 70
June 7th, 2012 04:29 PM
69convertible
Ninety-Eight
25
February 5th, 2009 01:43 PM
perro
September 3rd, 2007 01:30 PM
Quick Reply: Disk conversion; can I use the drum booster?
