Disk Brake Swap
Disk Brake Swap
I have a 70 cutlass disk brake car,and I want to put the disk brakes on a 72 cutlass drum car.Is there supposed to be a proportioning valve below the master cyl like Chevelles have.I do not see one on the 70,just lines from the master cyl down to the splitter block on the frame? I know the master is different between them,is the frame splitter the same? Should there be a proportioning valve somewhere? Thanks
delmontcrusier
May 28, 2023 07:37 AM
