Disc conversion plumbing issue
Old Feb 13, 2020 | 10:20 AM
Phoenix8990's Avatar
I have a 69 Cutlass, I picked up a set of disc brakes from a 71 or 72 and installed the discs, new master and proportional valve. My problem is plumbing. I was able to remove the line for the front brakes and cut, bend, and flare. There isn't room to work on the rear line in place and I can't get the nut loose on the distribution block. I wondered if I should heat it or would that be a disaster? Any suggestions? It's on the frame and almost no room to get at it good.
thanks,
Steve W.
Old Feb 13, 2020 | 10:53 AM
boese1978's Avatar
I got mine apart with a flare nut wrench.......
Old Feb 13, 2020 | 10:57 AM
Probably the one tool I don't have. Figures, I'll pick one up. 50 years can make it tough.
thanks,
Steve
Old Feb 13, 2020 | 11:46 AM
boese1978's Avatar
Good luck!
Old Feb 13, 2020 | 12:03 PM
The combo valve has rubber o-ring seals internally. Heat will destroy them. The real problem with the flare nut is that it has rusted to the tube. Expect the tube to twist and break as you unscrew the flare nut.
Old Feb 13, 2020 | 02:08 PM
Soak everything down with penetrating oil first.
Old Feb 13, 2020 | 08:57 PM
For days.
Old Feb 14, 2020 | 04:42 PM
droldsmorland's Avatar
CH3NO2 LEARN IT BURN IT
PB Balaster and or Castles "Thrust" are the only options for penetrant, with... yes, days of presoak before grabbing the fire wrench.
Cheap line wrenches are junk, The heads will flex and round off the nut crowns nicely. Look at Armstrong or Proto if you don't have Snap-On pockets. I have some old S&Ks that are stout. Harborjunk is use at your own discretion.
How crusty rusty is that area on your car? You may be farther ahead just cuttin everything out and starting out from scratch? It is a safety system.
Did you grab the front caliper rubber line to frame brackets off the disc brake car? You'll need em...and replace all 3 rubber lines.
Bee Saint Louis
Brakes/Hydraulic Systems
Jan 1, 2017 09:08 PM
olds68442
Feb 17, 2016 09:38 AM
olds68442
Feb 8, 2016 09:10 AM
70special
Oct 27, 2010 07:34 AM
sleeton
Nov 5, 2009 01:58 PM
