disc brake conversion question on 1965 olds cutlass rear questions
I recently picked up a 1965 oldsmobile cutlass rear. 10 bolt limited slip rear. I picked up the rebuild kit for it and the yoke and bearings.
my question is I was looking at brake options and found this post on pontiacs side and also on a chevelle site.
http://www.highperformancepontiac.com/tech/hppp_0606_pontiac_rear_disc_brakes/photo_01.html
basically the setup uses rear disc brakes off of a 1998-2003 s10/blazer. I've picked up the plate that bolt to axle tubes but I'm afraid to move forward in case I can't use them on this rear. Any infor would be great, thanks.
Mike Hateful
Mike Hateful
Mocephus
October 1st, 2021 09:45 AM
66ninetyeightls
Ninety-Eight
March 12th, 2015 07:21 AM
Maverick
Brakes/Hydraulic Systems
June 26th, 2013 08:21 AM
65dynamo
May 19th, 2013 10:30 AM
