Disc brake conversion.
If this was asked before I'm sorry, I looked and didn't find any answers. I have a 1971 oldsmobile cutlass convertible. I just purchased a 8.5 posi rear end with 3.42 gears. I think I want to upgrade to disc brakes. My question is should I do front, back or all? I currently have drums all around. I have 235 60/14 tires. eventually I will move up to 15 inch tires. Can someone recommend a good tire size for my 14's. Thanks in advance.
Some 14 inch runs won't work with disc brakes. just a FYI I think that the 71 wheels should work but not positive. There is a ton if threads here on this subject search could be your friend on finding a good kit or parts to build your Own
There are only two readily available choices for tires that are close to the diameter of the original tires, 215/75-14 or 225/70-14. Both of these are about 26.5" in diameter. The largest 60-series tire you can get is 245/60-14, which is about an inch smaller in diameter. I think these leave waaay too much daylight between the tire and the wheel opening.
factory disc set-up
I'd like $250 plus the ride (as they say). The rotors look like they still have some life left in them (you can still see the wear groove). I removed one of the calipers to make sure they weren't frozen up and it moved smooth enough to remove the pads; but you should definitely plan on rebuilding the calipers with new seals and pads and have the rotors turned down for straightness.
