Disc brake conversion
Old Nov 30, 2013 | 10:15 AM
stats5's Avatar
I recently purchased a 71 Cutlass Supreme with drums at all four corners, want to convert just the front, Knowing that you'll have prob done this a few times LOL . Part numbers from parts stores to build my own kit or just purchase the kit available from Summit. Thanks in advance.
Old Nov 30, 2013 | 11:45 AM
oldstata's Avatar
Justin
Look around you can better prices what kit are you looking into ?
I chose the "right stuff detailing " brand over all looks to be a good kit well reviewed
I chose to buy my kit off a eBay vender buts it's the right stuff detailing kit they,buy in bulk so they sell it cheaper than going to the right stuff. I guess the down fall might be warranty anything, but I have not installed yet it's my winter project
I spent 644 to my door with the slotted rotors and braided lines and powder coated caliper
I only thing I need is make new hard lines or buy prebent ones
Good luck on your quest
Old Nov 30, 2013 | 01:48 PM
Search is your friend:
https://classicoldsmobile.com/forums...sk-brakes.html
Old Nov 30, 2013 | 03:04 PM
kitfoxdave's Avatar
If you get right stuff kit off ebay MAKE SURE it is for your Oldsmobile! The Standard vanilla kit did not fit worth a darn! I ended up getting new lines by talking with Todd in tech support. The routings of the other ones were too close to the exhaust.
Old Nov 30, 2013 | 03:11 PM
oldstata's Avatar
Justin
I talked with them as well before buying they only said prebent lines were a issue not the brake kit it self
Is this where you were having issues ? With the brake kit or prebent lines I didn't buy the lines only the brake kit
Old Nov 30, 2013 | 04:55 PM
kitfoxdave's Avatar
Issues with the pre-bent Stainless lines. Once I got the ones for a 72 cutlass from them, they fit with a little bit of tweaking. A couple of us ended up working with Todd to get our lines sorted out. Going from Drum to Disc with existing steel lines, I think you may need to tweak a bit to get them to fit the proportioning valve (unless you put a manual valve in your system and go the distribution block route)
Stats 5, are you in Florida by chance? I have the old front disc setup from my 72 that I replaced when I went to disc all around. If you are close I could make you a REALLY GOOD deal on some used parts.... Discs, calipers, Dust guards, proportioning valve, master cylinder, etc.... (I was about to toss them out, sick of tripping over them!) They are heavy, so you would NOT want to ship!
Old Dec 3, 2013 | 02:18 PM
stats5's Avatar
thanks everyone for your imput. I did go with the right stuff kit. I figured I will bend my own lines hard lines. I do appreciate all the help.
Mocephus
Oct 1, 2021 09:45 AM
Maverick
Brakes/Hydraulic Systems
Jun 26, 2013 08:21 AM
ricardo
Jul 27, 2010 05:26 AM
68droptop
Mar 31, 2009 06:10 PM
Want-A-Vert
Jan 4, 2007 07:19 AM
