CPP Hydra Boost Brake System
Old Sep 7, 2015 | 02:07 PM
Stevec's Avatar
Just purchased a complete hydra boost brake system from Classic Performance Products. I will probably install it over the the winter, it came with everything needed to complete this installation.
I'm just curious if anybody has used this set up and if so how they like it!
Old Sep 8, 2015 | 07:14 AM
oddball's Avatar
I built my own hydroboost setup from various parts and pieces. I only have about 10" vacuum at idle, so it's a must-have for my build.
Overall I like it. Had to use the manual brake hole in the brake pedal. The vacuum hole resulted in a very high and hard pedal. Manual hole gets a good amount of travel but a pretty soft pedal. I might drill a hole somewhere in the middle.
There's not as much pedal feedback, but it'll lock up the wheels really easily. So you get plenty of pressure! Hitting the brakes also bogs down the engine due to load on the PS pump, so make sure you have a good idle. You don't want the engine to die because you turn while braking.
Old Sep 8, 2015 | 02:56 PM
Stevec's Avatar
Thanks Oddball,my brake pedal only has 1 hole in it (pretty sure) so I'll start there the car was originally fitted with manual brakes.
Old Sep 9, 2015 | 06:59 AM
Look again. Every 68 Olds brake pedal I've ever seen has two holes.
Old Sep 9, 2015 | 03:02 PM
Stevec's Avatar
I'll check it out Joe!
Skeetman
Suspension & Handling
Mar 5, 2019 01:14 PM
copper128
Dec 5, 2013 06:59 PM
tpawlik
Brakes/Hydraulic Systems
Sep 2, 2011 08:49 AM
BerBer5985
Dec 9, 2009 12:27 PM
cfair
Sep 13, 2009 05:00 AM
