Conversion to Front Disks Finally Finished...and Working
Old Jun 12, 2014 | 08:18 AM
brown7373's Avatar
After way too much time with leaking rebuilt calipers, I completed my brake conversion. I replaced all the bushings, hoses, ball joints and front & rear springs. No more leaks. I had the car realigned and it really drives nice. My only issue is I am getting some pulsing when I apply the brakes.
I used parts from a doner car. The rotors had been cut and I used new bearings and repacked and adjusted to specs. Is there anything OTHER that an out of round rotor I might check that could cause the pulsing?
There was a thread I read the other day about lousy brake rotors that warp almost immediately. I think I may replace the rotors, but do not want junk from China or some other bargain rotor.
Any recent experience with NAPA Premium or Ultra Premium, or the Wagner rotors? Other than my recent issues with calipers, I have never had an issue with NAPA products.
Old Jun 12, 2014 | 07:41 PM
johnnyjaws's Avatar
do u have a leaking master cyclender ?
Old Jun 12, 2014 | 07:49 PM
I'd check for any grease that might have gotten onto the brake rotor. Spray both the rotor and pads down with brake clean and see if it helps. When you had the rotors turned did you have them checked for run out? If you have a bad rotor to start with it doesn't help.
I had some really good luck with Raybestos rotors. NAPA premium? Good and bad. Depends on the application...
BTW, how'd you solve the problem of your RF caliper leak?
Old Jun 13, 2014 | 05:43 PM
My experience has been that the inexpensive off-brand rotors (made in China, India, etc) are much thinner metal than the more expensive premium brands. Wagner, Raybestos, etc premium parts should be good. Have the parts guy pull each and compare the thickness.
Oldsragger
Brakes/Hydraulic Systems
32
Jun 29, 2015 01:27 PM
djcrook73
32
Nov 5, 2014 07:27 PM
gearheads78
Feb 1, 2013 01:06 PM
therobski
May 18, 2011 06:11 PM
blonzz
Sep 13, 2004 10:35 AM
