Calipers
Old Jun 30, 2016 | 12:16 PM
ostie13's Avatar
Calipers
What is the difference in Un-loaded,loaded and semi loaded calipers.?
Old Jun 30, 2016 | 12:30 PM
jensenracing77's Avatar
Loaded is with the brake pads, new pins and everything needed to just bolt them on. Unloaded is just he caliper. Never seen semi loaded listed before.
Old Jun 30, 2016 | 12:57 PM
I think semi-loaded is with the pads but not the mounting hardware.
Old Jun 30, 2016 | 01:44 PM
76olds's Avatar
Hookers under Hood
Semi loaded is installed on the car but no brake fluids if I remember correctly. Stupid terms if you ask me .
Old Jul 1, 2016 | 07:46 AM
Uh, I don't think so. Unfortunately, I also got it wrong above.
Semi-loaded really only applies to calipers for newer cars that come with sliding brackets. You can get bare (unloaded) calipers. You can get loaded calipers that come with pads (usually lower-grade) and mounting brackets. You can get semi-loaded that come with the mounting brackets but without the pads. This doesn't really apply to Oldsmobiles with the sliding calipers.
Old Jul 1, 2016 | 09:52 AM
Octania's Avatar
Loaded calipers can't walk.
Semi-loaded calipers stagger a bit but manage to walk along.
Old Jul 1, 2016 | 10:03 AM
It disturbs me that I was trying to come up with a clever response along those same lines...
Indy_68_S
Brakes/Hydraulic Systems
Apr 16, 2010 01:51 PM
Wilson05
Jan 7, 2010 12:16 PM
wired
Jan 30, 2009 02:18 PM
68ragtop
Nov 24, 2008 01:57 PM
Aussie67Delta88Custom
Oct 12, 2008 12:16 PM
