caliper bolt slide question.
Old Nov 29, 2013 | 02:10 PM
rmoths's Avatar
I'm putting on new calipers and I have a question about the bolt slides.
Does the bolt itself slide in the sleeve for caliper adjustment or does the slide itself move in the caliper. Should I lube the slide when I put it in the caliper or just tap it in place dry. Sorry if it's a dumb question, but this where I come to learn. Barb.
Old Nov 30, 2013 | 03:19 AM
Yellowstatue's Avatar
Lube it with white lithium grease...and assemble.
Old Nov 30, 2013 | 04:38 AM
jensenracing77's Avatar
I always pull the sleeves out and use white lithium like yellowstatue said. The caliper slides on the sleeve. The sleeve does not slide on the bolt. Also grease the outboard side of the pin, It does not have a sleeve on that side.
Old Nov 30, 2013 | 06:22 AM
I use silicone grease, not petroleum-based grease, on these parts to avoid damaging the rubber o-rings.
rmoths's Avatar
OK, Thanks. I know when in doubt to ask here. Thanks Barb.
Old Nov 30, 2013 | 08:58 AM
Octania's Avatar
I agree with Joe, though ANY grease is better than none.
I grease EVERYTHING. If you want it to come apart easily next time then anti-seize or any sort of lube on the threads is a good idea. Silicone RTV where the pads touch the calipers helps avoid squealing later also.
golow1
Feb 18, 2014 02:33 PM
stlbluesbrother
Jul 28, 2013 03:47 PM
jdana24
Jul 3, 2012 09:03 PM
Alex72cutty
Brakes/Hydraulic Systems
Jun 4, 2012 06:55 PM
knighthawk
Jul 7, 2011 10:58 AM
