Brass Brake Unions
Old Jun 16, 2012 | 04:42 PM
60193W30's Avatar
Brass Brake Unions
Fellas...
I need some help finding a few inverted flare fittings...
Any help would be appreciated...
Option 1
7/16 female to 3/16 female
Option 2
7/16 female to 7/16 female
7/16 male to 3/16 female
Joe
Old Jun 16, 2012 | 04:54 PM
coppercutlass's Avatar
Chevy budget Olds powered
You might have to use adapters. Are they for the prop valve.
Old Jun 17, 2012 | 07:57 AM
60193W30's Avatar
I am using them to connect factory lines to the prop valve. The front lines are done & I am having issues w/ the rear brake line union. (finding it) A friend of mine found a 7/16 to 7/16 line & now we would only need the 7/16 - 7/16 female to female union to complete the job.
Anywhere local stock these or do you know where I could order it???
Joe
Old Jun 17, 2012 | 10:40 AM
I know exactly what lines too. I used an adapter the car quest in roselle il. Had them.
Old Jun 18, 2012 | 09:44 AM
Well stocked NAPA stores have a selection of these adapters. You can also find them on line. The trick is to search for Master Cylinder Adapters.
Old Jun 18, 2012 | 10:54 AM
joe the only reason i mentioned that car quest is ., if im correct that is his zip code on his name from the last time i asked and it's the next town over from that particular town . i store my car in roselle so car quest is the auto parts i go to.
Old Jun 18, 2012 | 11:20 AM
OK, that wasn't a criticism. I know firsthand that NAPA has them. I don't know anything about CarQuest - the only one near me sucks, so I don't use them. Just offering options.
Old Jun 18, 2012 | 11:26 AM
It's all good. I know napa will have them too I use both car quest or napa.
Old Jun 22, 2012 | 05:17 AM
60193W30's Avatar
Thanks for the info fellas...
It is greatly appreciated!!!
I need to know your thoughts on this set-up...
My plan is to replace the system when I give the car a facelift so this is why I went this route w/ the line...
From the prop valve I stepped down w/ two adapters 9/16 to 7/16... (line has 7/16 ends)
Tapped into the existing line & stepped up in the same fashion...
Is it save to have this many adapters & a union on this line??? (for normal driving etc...)
Thanks a ton!!!
Joe
jkoester122
Sep 8, 2011 07:48 PM
defiant1
Jun 7, 2011 10:07 AM
olds67
Mar 6, 2011 12:58 AM
cfair
May 31, 2009 09:18 AM
65 starfire
Feb 2, 2008 07:03 PM
