Braking force
Old Aug 6, 2022 | 09:02 PM
griffey57's Avatar
Braking force
On 4 wheel drums, does the front do most of the braking or is it equal all around
Old Aug 7, 2022 | 05:33 AM
On any car most of the braking is done with the fronts. This is why on four wheel drum cars the front brake shoes are larger than the rears and the front wheel cylinders typically have a larger bore than the rears. Any front engine car has a front weight bias (typically 60% or so on the front wheels and the rest on the back, and coupled with the forward weight transfer when you hit the brakes, most of the load goes through the front tires. Think about that the next time you want to put 4" wide frontrunner tires on your ProStreet car.
Her69olds
Brakes/Hydraulic Systems
Mar 11, 2015 06:05 PM
73aussie455
Jul 2, 2014 02:34 AM
dewcrazzy
Mar 25, 2013 07:51 PM
442NDTSS
Sep 30, 2012 02:59 PM
cargo442
Aug 15, 2011 06:17 AM
