brake problem!!!
Old Jan 28, 2010 | 04:27 PM
71cutty's Avatar
brake problem!!!
I have a 71 cutlass supreme i love the car but my brake light on the dash is on and wont go away......i changed and bled the master because there was a small leak there but the light is still on.... I'm guessing its the brake sensor but i 1 i cant find one online anywhere and 2 i cant find it under the hood..... I really need some help and i would greatly apreciate it..... thanks in advance for any feedback anyone can give me
Old Jan 28, 2010 | 05:12 PM
greenslade's Avatar
Don't know any thing about 71 cutlass!could it be the park brake light?You may have to re set the proprtion valve just follow the brake lines from master cyl to frame valve should be on frame the sensors may be there.
Old Jan 28, 2010 | 05:48 PM
compedgemarine's Avatar
the brake light works off of two sensors. one is the emergency brake, the other is in the distribution valve on the frame. start with the e-brake. if the pedal is not all the way up or not pushing the switch in it will turn on the light. the other as was stated is if the system lost presure on one half the distribution valve will shuttle over to turn on the light and will sometimes stay over. if that happened then you will not have pressure on one half (front or rear).
Old Jan 28, 2010 | 06:51 PM
Lady72nRob71's Avatar
Here is a detailed thread on the brake light staying on...
https://classicoldsmobile.com/forums...html#post68944
If not the parking brake light switch, then disconnect the wire at the proportioner valve on the lower left frame rail.
If light goes out, either you have a hydraulic pressure imbalance or the valve needs replacement. I thought I have seen these sold somewhere.....
Old Jan 28, 2010 | 07:10 PM
Limey's Avatar
Originally Posted by lady72nrob71
here is a detailed thread on the brake light staying on...
if not the parking brake light switch, then disconnect the wire at the proportioner valve on the lower left frame rail.
If light goes out, either you have a hydraulic pressure imbalance or the valve needs replacement. I thought i have seen these sold somewhere.....
thanks i bookmarked that page very good to know
Old Jan 29, 2010 | 06:03 AM
Oldsguy's Avatar
Past Administrator
Welcome to CO.
Old Jan 29, 2010 | 07:44 AM
jeffreyalman's Avatar
pull up on the parking brake too just to be sure
veltboy618
Brakes/Hydraulic Systems
Jul 14, 2011 07:10 PM
scubastever
Sep 24, 2010 11:33 AM
MeanGrnGt
Jul 20, 2008 05:34 PM
jk121
May 14, 2007 01:49 PM
js_specials
Aug 18, 2006 10:31 AM
