Brake Fluid Leak - Driver Side Floormat
Hi Olds fans,
I've got a 72 Cutlass S (350/4bbl/TH350/non-powered drum brakes all around). After taking her for a spin last week (80 degrees in Central PA!), I noticed fluid had dripped onto the driver side floormat (luckily rubber). I'm pretty convinced it's brake fluid. When I press the brake hard, I can see more drip down.
My research thus far has led me to think that the master cylinder has gone south, and it needs replaced. I would probably have to take it to a shop due to my lack of space and local car friends right now (would need help for the bleeding).
My questions are:
1. Is there anything I should look at or try before replacing the master cylinder? Are there other possible causes for this leak.
2. Do you have any recommendations on where to get a replacement master cylinder? Are there any other parts required? I figure the more I can bring to the shop, the better off I'll be.
3. Would this be a good opportunity to add a brake booster? (I know, I know. Switch to discs...
). As much as I've adjusted to the 'Flintstone stop', a little help wouldn't hurt hehe.
I apologize if this has been answered. I searched the site best I could before posting, but didn't quite find a good answer. I'm also kind of a newb, so be gentle
Thanks in advance!!
PS - It's been awhile since I've posted, but I'm glad to see the site still chirpin' away!
You guys have saved me more than once, and someday I hope I can be helpful.
My questions are:
). As much as I've adjusted to the 'Flintstone stop', a little help wouldn't hurt hehe.I apologize if this has been answered. I searched the site best I could before posting, but didn't quite find a good answer. I'm also kind of a newb, so be gentle
.Thanks in advance!!
You need an assistant for about five minutes, and no time on your back.
As for where to get one, I just got a rebuilt for my Delta at the local Advance Auto for $15.00. I know, that's not the "best" available, but it works for me right now. Since you have manual brakes, though, I am not sure whether your M/C would be harder to find (though I suspect not).
I've never done a manual M/C on a GM before (had a Valiant with one), but I think there may be an under-dash connection to the brake pedal that you have to disconnect.
jstrits
Feb 18, 2015 05:44 AM
yeahbuddy
Brakes/Hydraulic Systems
Jan 15, 2014 02:10 PM
cfair
Jun 8, 2009 12:37 AM
