Brake Combo (Prop) Valve leaking...
Old March 25th, 2013, 04:15 PM
Mark71's Avatar
I installed a new MC, booster, combo valve and stainless steel lines about a year ago now. Everything's been great, up until recently.
There's a small leak at the pin on the combo valve (under the dust cover, opposite end from the output for the rear brakes). I've read a lot about those aftermarket GM-style prop valves leaking from under the dust cover.
So I have two options:
1) A new GM-style prop valve.
2) A new adjustable prop valve.
I would rather not re-bend the lines and my flaring tool will not flare SS. Anyone know of an adjustable type of prop valve that has the GM-shape?
Also, does anyone know what the GM-style prop valves are configured for pressure-wise? Is it like 60/40 front bias or...?
Thanks!
Mark71 is offline
Old March 25th, 2013, 04:57 PM
Boldsmobile's Avatar
You have a third option. Have it rebuilt.
Boldsmobile is offline
Old March 26th, 2013, 08:39 AM
Beat me to it. The prop valve seals are just o-rings. You can do this yourself.
joe_padavano is offline
Old March 26th, 2013, 06:05 PM
Mark71's Avatar
Ok... I thought those were sealed units. Mine is aftermarket, actually pretty new. Assuming I can rebuild it - any idea where i could get the rebuild parts? I guess I just need the seals...
Mark71 is offline
rspreen1
July 4th, 2015 01:13 PM
NHolds
April 10th, 2013 04:02 PM
1970VistaCruiser
January 15th, 2013 06:16 PM
dgy
Brakes/Hydraulic Systems
April 6th, 2012 11:03 AM
nofiveo
July 28th, 2011 02:08 PM
Quick Reply: Brake Combo (Prop) Valve leaking...
