Brake Booster fitment?
I've read through a lot of posts but not finding any actual recommendation for a booster. I have a 69 Cutlass w/455 disc/drum set up. The current 11" booster is leaking so I thought I would go with a 9" double diaphragm from Speedway as I couldn't find them at Rock. I currently have about a 1/2" clearance with the valve cover so I could go with any size. This is the one I was considering. https://www.speedwaymotors.com/Tuff-...ch,278180.html. I just wanted to make sure there are no issues with rod length or anything else.
thanks,
Steve
thanks,
Steve
thanks,
Steve
thanks,
Steve
The stock 11" is a single diaphragm and has about 95 square inch of area while a 9" double diaphragm would have about 128 square inch. (thanks to Joe Padavano who schooled me on this). The 9" double will provide you with better power braking assistance.
plee3 64Olds
Brakes/Hydraulic Systems
April 28th, 2011 10:01 AM
