Brake Booster fitment?
Old Jul 25, 2021 | 10:05 AM
Phoenix8990's Avatar
I've read through a lot of posts but not finding any actual recommendation for a booster. I have a 69 Cutlass w/455 disc/drum set up. The current 11" booster is leaking so I thought I would go with a 9" double diaphragm from Speedway as I couldn't find them at Rock. I currently have about a 1/2" clearance with the valve cover so I could go with any size. This is the one I was considering. https://www.speedwaymotors.com/Tuff-...ch,278180.html. I just wanted to make sure there are no issues with rod length or anything else.
thanks,
Steve
Old Jul 25, 2021 | 10:16 AM
66SportCoupe's Avatar
Personally I would stay with the original size booster.
Old Jul 25, 2021 | 02:09 PM
sysmg's Avatar
I would send my original booster out to be rebuilt. I've had good luck with BoosterDewey aka Power Brake Booster Exchange.
Old Jul 25, 2021 | 07:30 PM
442Dude's Avatar
I installed the 11" booster from Right Stuff and moved my proportioning valve due to the large headers. My setup is working great even with the roller rockers. Good luck on your decision.
Old Jul 25, 2021 | 09:01 PM
pettrix's Avatar
thanks,
Steve
If you are not worried about keeping the car 100% stock looking, go with the smaller 9" double diaphragm brake booster. It will provide more valve cover clearance, take up less space and provide better power brake assistance vs the stock 11".
The stock 11" is a single diaphragm and has about 95 square inch of area while a 9" double diaphragm would have about 128 square inch. (thanks to Joe Padavano who schooled me on this). The 9" double will provide you with better power braking assistance.
truckman5000
May 17, 2017 06:21 PM
64Rocket
Brakes/Hydraulic Systems
Nov 14, 2012 06:14 PM
piperman60
Tech Editor's Desk
Jun 27, 2012 04:39 PM
smcurro
Oct 14, 2011 12:55 PM
plee3 64Olds
Apr 28, 2011 10:01 AM
