bendix master cylinder
So today i pulled off the master cylinder to get a replacement and the auto parts store was showing something totally different then what i have. Is there any differences in master cylinder's from any of the 62's? The one i have has a part number of 5460982. Could this be the correct one or could it be from another GM?
While I agree that the dual reservoir M/C is safer, you will need to replumb your brake lines to use it. Also, four wheel drum brakes do not (and should not) use a proportioning valve. This is for disk brakes only.
I'm not to worried about originality but on a budget the disc conversion will not work for me just yet. Is there anyway to do a low buck conversion by pulling a majority of the system from another car?
[QUOTE=lowdynamo;52177] . Is there any differences in master cylinder's from any of the 62's QUOTE]
I am pretty sure Olds used a Bendix and also used a Moraine master cylinder in '62's. Two different products, two different part numbers, but both work for the '62's. One book I have only goes to '61 part numbers, sorry.
Its ok i actually went and got one from a 62 imapala and works just fine. I still have my original that i took off the car to get rebuilt once i'm a little further on the car just for a hint of originality under the hood.
zebrostripe
July 10th, 2014 05:27 PM
1970VistaCruiser
November 22nd, 2012 04:55 PM
