Balance valve leaking - upgrade?
Old April 6th, 2016, 04:48 AM
EightballZ's Avatar
hey guys,
that balance valve is leaking on my 1970 toronado so theres always air comming out of the rear cylinders while brake bleeding (see pic). can't find any replacements but i hear that with 1971 model theres some sort of a combined distribution block that includes the balance valve.
since i'm not familiar with these certain valves, could you guys point me in the right direction which distribution block (maybe from inline tube) i should buy?
i also would like to get rid of the metering valve in the second picture...are there any newer blocks that include these too?
thanks
EightballZ is offline
Old April 6th, 2016, 06:44 AM
Do you actually see brake fluid coming out of your current balance valve? If not, how do you know it's leaking or even the source of the air? Are you sure the air isn't just coming from around the threads of the bleeder screws when you loosen them?
joe_padavano is online now
Old April 6th, 2016, 07:08 AM
EightballZ's Avatar
hey joe,
yes i see braking fluid comming out of it.
Old April 6th, 2016, 07:12 AM
Originally Posted by EightballZ
hey joe,
There isn't much to these. You should be able to rebuild it with some silicone o-rings.
Old April 7th, 2016, 07:24 AM
oddball's Avatar
Alternatively, you can pull all that stuff and switch to a 71 and later setup with the common combination valve. The same disc/drum valve was used on a wide variety of GM vehicles from 71 through 77 (or 79? or later?). That will require changing/modifying all your hard lines, though.
I have not seen a separate balance valve like that available. I expect it's just a proportioning valve, so you should be able to replace it with an aftermarket prop valve as well.
oddball is offline
Old April 7th, 2016, 08:46 AM
That particular valve is a couple of machined parts that screw together with a valve spool and spring on the inside. The seals are either flat washers or o-rings. Re-plumbing the car for a different valve is a waste of time. Just rebuild the valve with new seals. Problem solved. We've spent more time talking about it than it takes to actually do it.
Old April 7th, 2016, 11:29 AM
EightballZ's Avatar
thank you guys. gonna pull the valve anyway so i'm going to check for the necessary seals after disassembly.
didn't know its such a big job to go the combination valve route, but i guess the inlets / outlets have a different size compare to the stock system, right?
Old April 8th, 2016, 07:36 AM
oddball's Avatar
Don't know about sizes, but certainly different locations. You can get pre-bent lines from the usual manufacturers that tend to be "close".
I didn't know that valve comes apart that easily! If you can find good orings, then go for it.
oddball is offline
Old April 9th, 2016, 04:44 AM
EightballZ's Avatar
so i pulled the valve today. some crud came out of it but almost no brake fluid.
i dont know how these valves work, but where my screwdriver is pointing..there is a hole and a second one on the opposite side. you can see through the valve there o.O
looks like the outer o-ring is missing?
Old April 10th, 2016, 03:56 AM
EightballZ's Avatar
ok i replaced the missing o-ring with the size i measured...which was obviously the wrong size, so i put a smaller diamter o-ring on.
took some time to bleed the brakes but as it came to the point where i was almost ready with bleeding all the air out of the system it started to leak again...o-ring too big i guess.
why does this valve even need these holes??
garys 68
Wheels and Tires
36
May 18th, 2017 11:18 AM
gearheads78
October 9th, 2010 08:53 PM
sammieolds
August 10th, 2010 02:49 PM
coltsneckbob
Wheels and Tires
April 9th, 2010 12:36 PM
Quick Reply: Balance valve leaking - upgrade?
