79 Pontiac Brakes
Old August 1st, 2010 | 04:07 PM
brettharmon's Avatar
79 Pontiac Brakes
I have a 1972 Cutlass Supreme that has Drum front Brakes and want to convert to disc brakes Has any body tried disc brakes of a 1979 Pontiac trans Am Thanks
Old August 1st, 2010 | 05:45 PM
This comes up a lot. The F-body spindles are taller, have a different steering arm location (causing some bump steer), and (most importantly) use ball joints with different stud taper. You can swap the upper ball joint easily, but the lower has a larger body diameter and must be machined to fit the A-body control arm. The taller spindles do help slightly with handling, but you'll need offset upper control arm shafts to get the alignment correct. Finally, you still have the bump steer problem.
I'll respond as I always do. If there were an easy swap using later model parts, the repro houses wouldn't charge what they do for the A-body disk brake kits.
Old August 1st, 2010 | 06:17 PM
Thanks I thought it would have been tried before but i needed to ask OK next question where and what do you guys recommend as a good front disc brake conversion The car has 14 inch rims and if I have to will upgrade to a bigger rims then so be it Thanks again
Old August 2nd, 2010 | 10:49 PM
Aceshigh's Avatar
Joe posted a good thread here to review if you want inexpensive options for front disc brake upgrades.
https://classicoldsmobile.com/forums...sk-brakes.html
72allblackcoupe
April 6th, 2014 07:20 PM
1carsick
Brakes/Hydraulic Systems
23
October 2nd, 2012 05:50 PM
russell-t
April 30th, 2011 05:56 AM
Old School
Drivetrain/Differentials
September 4th, 2007 09:11 AM
rodknocker
April 17th, 2006 11:02 AM
Quick Reply: 79 Pontiac Brakes
