71 Cutlass Power Booster Removal
Old Jul 16, 2023 | 09:52 AM
timothypaul's Avatar
Hi All, tomorrow I am going to replace the power booster & master cylinder on my 71 Old’s Cutlass Supreme. Just looking for any heads up advice before I start. It was replaced about 4 years ago so I am not anticipating any frozen bolt issues. In searching various threads over the years I see some people recommend removing the windshield wiper motor, others suggest remove the inner fender, etc.
Looking for wisdom from those with experience.
Thanks, Timothy
Old Jul 16, 2023 | 10:53 AM
I replaced mine without removing anything else. It’s a tight fit to reach at least one of the nuts. Having a ratcheting box end wrench would make the job a lot easier.
Old Jul 16, 2023 | 11:56 AM
Why do you need to replace a power booster that's only four years old?
Old Jul 16, 2023 | 01:15 PM
Autozone special I guess - big swoosh noise in interior of car when pressing brake pedal, and can’t get air to stop coming out of calipers. I used a cardone reman when I did this back then, was on a very low budget.
Replacing master cylinder & booster with a Leeds LN-6. Also installing all new brake lines.
Old Jul 16, 2023 | 01:34 PM
4speed455's Avatar
I did it recently without removing anything including wiper motor, or inner fenders. A few months earlier I had my fenders, inner fenders and hood off. It would have been easier to do it then for sure, but it wasn’t too bad. I also did not remove the lines to my master cylinder so I didn’t have bleed the brakes afterwards. All in all took a few hours.
Old Jul 29, 2023 | 11:42 AM
MPSax's Avatar
I removed the wiper motor. Made it easier.
Spray PB Blaster on the threads first.
I had a nightmare of a time.
Old Jul 29, 2023 | 01:24 PM
jfb's Avatar
jfb
reply
Dam ßhame about the booster I replaced mine in 03 no problems since. Use kroil for the nuts and if you can do not pull the lines it will be less work overall be careful on not collapsing the lines and slide it in behind the master cylinder. With minimal master cylinders maneuvering. Paint the booster first if not really coated good. Rust at the master area can be a problem.
oldsdriver1218
Brakes/Hydraulic Systems
Feb 9, 2020 04:50 PM
2oldsguy
May 18, 2018 11:00 AM
Tiha
Jun 7, 2017 10:59 PM
71cutlass350
Aug 15, 2016 12:10 PM
Don R.
Oct 7, 2015 09:22 PM
