70 Cutlass Rear Backing Plate - Gasket or no?
Old Sep 2, 2023 | 01:54 AM
VI Cutty's Avatar
I've got a 10 bolt 8.5" rear end with bolt in axles going into my '70 Cutlass and I'm just bolting up the backing plates and bearing covers. Should there be a gasket between the backing plate and the axle housing? I have one (part is labelled for 64-68 Cutlass though) but couldn't find reference to anything in the assembly manuals. If the gasket is used, does it go on dry or with some goop?
Also, any tricks to getting the outer seal started into the housing?
Old Sep 2, 2023 | 05:47 AM
There was a gasket originally. You can also just use RTV.
Old Sep 2, 2023 | 12:53 PM
I have swapped quite a few rearends in my car and never saw a gasket on the backing plate. I suppose it’s a dust seal?
Old Sep 2, 2023 | 01:19 PM
Yes, that's exactly what it is, dust and water seal.
Old Sep 2, 2023 | 01:47 PM
It's not much of a gasket, more like a piece of paper. I'll reuse it if it is still intact, but I won't replace a missing one.
ub2693v
Jun 3, 2022 11:56 AM
70-455
Brakes/Hydraulic Systems
Nov 23, 2019 10:08 AM
Harmon
Drivetrain/Differentials
Oct 27, 2013 07:33 AM
oldzy
Sep 27, 2010 05:49 AM
mcutlass1969
Sep 22, 2010 12:48 PM
