69 cutlass supreme front brakes
I just bought this totally stock Cutlass supreme for 500 bucks, i was bleeding the brakes on the back just fine, how do i get the drums off of the front to inspect the brakes it looks solid, also where can i find a disc brake upgrade? Thanks for you help,
love newbie!
love newbie!
The original Olds front drums come off with the hub.
You need to remove the cotter pin, nut, washer and outer wheel bearing. The drum is removed with the hub, inner wheel bearing and seal.
There are many kits on the market to install disk brakes on the A body GM cars. If you go to a bone yard the brakes from any A Body (Cutlass, Skylark, Tempest, Chevell); 2nd Gen F body (Firebird, Camaro); X body (Nova, Omega, Apollo, Ventura) or Monte Carlo and 1969 and later Grand Prix. You will need the master cylinder, proportioning valve, spindles, rotors and calipers.
DR_DAN
March 9th, 2015 05:48 PM
1carsick
Brakes/Hydraulic Systems
23
October 2nd, 2012 05:50 PM
russell-t
April 30th, 2011 05:56 AM
