69 cutlass supreme front brakes
Old Aug 10, 2004 | 03:08 PM
Supreme's Avatar
Red face
I just bought this totally stock Cutlass supreme for 500 bucks, i was bleeding the brakes on the back just fine, how do i get the drums off of the front to inspect the brakes it looks solid, also where can i find a disc brake upgrade? Thanks for you help,
love newbie!
Old Aug 11, 2004 | 06:58 PM
jdorour's Avatar
Post
The original Olds front drums come off with the hub.
You need to remove the cotter pin, nut, washer and outer wheel bearing. The drum is removed with the hub, inner wheel bearing and seal.
There are many kits on the market to install disk brakes on the A body GM cars. If you go to a bone yard the brakes from any A Body (Cutlass, Skylark, Tempest, Chevell); 2nd Gen F body (Firebird, Camaro); X body (Nova, Omega, Apollo, Ventura) or Monte Carlo and 1969 and later Grand Prix. You will need the master cylinder, proportioning valve, spindles, rotors and calipers.
DR_DAN
Mar 9, 2015 05:48 PM
72allblackcoupe
Apr 6, 2014 07:20 PM
1carsick
Brakes/Hydraulic Systems
23
Oct 2, 2012 05:50 PM
russell-t
Apr 30, 2011 05:56 AM
ungerstruck
Jun 5, 2009 03:29 PM
