69 Cutlass front brake drums?
http://www.rockauto.com/catalog/x,ca...,parttype,1744
Note that you may need to press the studs out of the hub to change the drum.
69 cutlass front drums
Joe,
Thanks a lot for your reply. I did go to Rockauto, but I am not sure where you found that part type 1744? I do see a 1917145 #, which is their #18B469. That looks like a front drum for a 69 cutlass? I have the drums with the hub pressed on, I can't seem to find one like this. Is that what you meant when you said to use new studs? Also, use the old hubs? I don't have a means of pressing these off, and they are rusted up pretty good. I have said before on this site, that I am at the low end of the learning curve, so thanks for bearing with me. I would greatly appreciate any guidance you can offer.
Thanks again,
Howard
___________________
69 Cutlass S
Thanks again,
Howard
___________________
69 Cutlass S
I took my drums to a machine shop, they pressed out 3 studs that were NG, then turned them. So far they seem to be fine. Thanks for the offer of the drums from your F85, maybe someone else will have an intrest.
BoutTime68
Brakes/Hydraulic Systems
March 26th, 2014 03:07 AM
yeahbuddy
24
December 12th, 2011 03:09 PM
