69 Cutlass front brake drums?
Old May 22, 2009 | 12:45 PM
my69olz's Avatar
Does anyone have any ideas on where to get front brake drums for a 69 cutlass?
Thanks for any and all thoughts.
_____________________
69 Cutlass S
Old May 22, 2009 | 02:34 PM
69 Cutlass S
http://www.rockauto.com/catalog/x,ca...,parttype,1744
Note that you may need to press the studs out of the hub to change the drum.
Old May 23, 2009 | 08:13 AM
my69olz's Avatar
69 cutlass front drums
Joe,
Thanks a lot for your reply. I did go to Rockauto, but I am not sure where you found that part type 1744? I do see a 1917145 #, which is their #18B469. That looks like a front drum for a 69 cutlass? I have the drums with the hub pressed on, I can't seem to find one like this. Is that what you meant when you said to use new studs? Also, use the old hubs? I don't have a means of pressing these off, and they are rusted up pretty good. I have said before on this site, that I am at the low end of the learning curve, so thanks for bearing with me. I would greatly appreciate any guidance you can offer.
Thanks again,
Howard
___________________
69 Cutlass S
Old Jul 1, 2009 | 01:05 PM
72' Convertible's Avatar
Fresh Meat
I'm in the same boat, can't get the hubs out of the old drums. Anyone have an idea?
Old Jul 1, 2009 | 01:14 PM
svnt442's Avatar
I had to replace a hub on a 70 post I had. They come out. You need to get the studs out and then you can remove the hub.
I don't think you'll find a new replacement hub for that car.
Old Jul 1, 2009 | 01:23 PM
svnt442's Avatar
I looked under 1970 442 and found this:
RAYBESTOS Part # 2056 {PG Plus Outside Diameter 11.58" / 5 Bolts / Finned}
Front
$24.79$0.00$24.79
Old Jul 1, 2009 | 09:05 PM
kaz442's Avatar
I have a set of drum brakes complete(except steering arms) that came off my '70 F85 if any of you are interested. They were relitively clean. LMK Jkaz
Old Jul 2, 2009 | 08:27 AM
my69olz's Avatar
I took my drums to a machine shop, they pressed out 3 studs that were NG, then turned them. So far they seem to be fine. Thanks for the offer of the drums from your F85, maybe someone else will have an intrest.
BoutTime68
Brakes/Hydraulic Systems
Mar 26, 2014 03:07 AM
Bitburger
Jan 29, 2013 06:46 PM
yeahbuddy
24
Dec 12, 2011 03:09 PM
rpc45040
Dec 6, 2011 03:49 PM
coppercutlass
18
Dec 6, 2011 01:00 PM
