69 Cutlass Convertible emergency brake
Old Jul 12, 2021 | 08:43 AM
lala5818's Avatar
Is there a secret to removing the rear emergency brake line from the backing plate? Should I just destroy this clip and buy another one? Or can I even buy one of these clips?
Old Jul 12, 2021 | 09:49 AM
There is actually a tool for this, but a hose clamp works in a clinch. Do not break the locking device off.
Old Jul 12, 2021 | 10:15 AM
Sugar Bear's Avatar
Clean it all up lightly with a small wire brush, put some oil on the fingers/tabs and the hole in the backing plate. Open a small hose clamp, put it over the fingers/tabs, close the clamp enough to get ALL of the tips of the fingers worked through the hole. Once the tips are in the hole, remove the clamp and then the cable.
Good luck!!!
Old Jul 12, 2021 | 11:54 AM
lala5818's Avatar
Thank you
Old Jul 12, 2021 | 11:57 AM
lala5818's Avatar
One other quick question, I’m about 99% sure my Cutlass Supreme has power brakes. Before I start ordering brake parts how can I confirm that?
Old Jul 12, 2021 | 12:41 PM
Look for a vacuum booster behind the master cylinder.
Old Jul 12, 2021 | 02:48 PM
lala5818's Avatar
This is what I took out of the car during the dismantling phase
Old Jul 12, 2021 | 06:01 PM
Yellowstatue's Avatar
Imagine that. You do have power brakes.
Old Jul 13, 2021 | 04:52 AM
lala5818's Avatar
Thank you, I know these questions are silly but i'd rather be positive before spending a bunch of money.
rkk69olds
Brakes/Hydraulic Systems
Mar 27, 2021 12:13 PM
RockAuto
Sep 22, 2020 07:43 AM
Reese Neis
Sep 20, 2020 09:41 PM
mont1le
Feb 14, 2010 07:29 PM
ct1979
Apr 11, 2007 10:08 AM
