67 442 lost pressure
Lost my brakes. To come to a complete stop I have a little pressure on the pedal but after about 1/4 in I lose all pressure and foot goes all the way down to the floor. I’m not able to lock my wheels. Looking at bleeding the brakes, but wondering if its the booster. While checking the master cylinder I noticed a cast piece beneath the master cylinder with on hard line going to it. Wondering what it is. My car is a 67 442 w/ disks up front. Thank u in advance
Thank you all for the tips. I do not have any leaks so I will start at master cylinder.
Now because of the stop valve attached to my master cylinder, should I be looking at a drum/drum master cylinder? Or just put a modern disc/drum master cylinder and remove what I have?
It's most probably the MC, but I would:
(1) Open the MC reservoir to evaluate fluid level; and,
(2) Thoroughly examine each brake line attachment to wheel caliper for evidence of leaks (remove each wheel, rock each wheel on its spindle forwards/backwards trying to find a leak; and,
(3) Thoroughly examine the MC leaks.
If no leaks found, suspect the MC. As stated, the booster is not likely suspect since the booster only assists in application of foot-to-brake-pedal-to-MC effort (reducing this effort) - the brakes would still function w/o the booster with a great deal more effort, but the brakes would still function.
Don't forget to bench bleed the MC if you find you need to replace/rebuild the MC.
EDIT: You beat me by a couple minutes in posting. If confident of no leaks, as suggested elsewhere in the thread - suspect the MC.
Disk/drum MC it is.. do I keep the stop valve I have now?
I guess what I should also add is that at the frame I have a proportioning valve with one line connected from from the stop valve and another line connected from the master cylinder.
When I get my new MC will I still need both, proportioning valve at the frame and stop valve?
I’ve had disc/drums before but it was a newer set up with and adjustable prop valve, nonstop valve.
It isn't going to "hurt" anything by retaining the brake distribution block so you might just as well retain it since it's already plumbed into the front brake circuit.
Here's a decent thread from last year:
https://classicoldsmobile.com/forums...-valve-141880/
That's actually completely backwards. That external valve is a metering valve and the purpose is to delay the application of the FRONT brakes for a fraction of a second to allow the slop in the rear brakes to be taken up. If you look at the lines, the valve is plumbed into the front brakes, not the rear. The metering valve function is incorporated into the combination valve on the 1971-newer cars. Note that this is NOT a proportioning valve. The 1967-70 A-body cars did not use a prop valve, only this metering valve. The factory adjusted the front/rear brake force bias by carefully selecting the wheel cylinder sizes on these cars (disc brake cars used smaller rear wheel cylinders than did drum brake cars for 1967-70).
bigwillystyle
Brakes/Hydraulic Systems
September 16th, 2010 10:56 AM
